Sponsored by: Auxito
Cleared Codes No Start
Old Dec 14, 2008 | 12:43 AM
UnlimitedOffRoad's Avatar
UnlimitedOffRoad
I have a 00 f150 5.4 never had an issue with 210,000 besides coils, Has a micro max tuner installed just recently had pacesetter headers put on and a code jump up as p1151 lack of ho2 switch indicates lean. So heres the problem went to clear the code and start and just get a click. cleared the codes replaced the relay on the firewall tested the battery check the fuses. I jump the relay with a screwdriver and here a click at the starter and thats it.
Sounds like a major probem with ford no start isssues. Id like to hear from the people that had the same problem and how they fixed it.
Thanks in advance,
Unlimited
Old Dec 14, 2008 | 07:37 AM
projectSHO89's Avatar
projectSHO89
It's probably either the starter or one of the battery cables. Perhaps the battery or the solenoid (new does not guarantee that it is good).
You'll have to follow normal troubleshooting steps instead of guessing.
Steve
Old Dec 15, 2008 | 01:20 AM
UnlimitedOffRoad
power cable at starter was rotted off! nice job using dieletric ford
