simple question
Old Dec 13, 2008 | 11:32 PM
1545mike's Avatar
1545mike
simple question
First let me thank you guys for the help with getting my 87 started and out of the field. Second is that some sort of throttle position senser on the left (driver) side of the IP my 87 has one its an auto but my 84 doesnt its a standard. So I figure its something to do with the trans but not sure what to look for at the parts store.
Old Dec 14, 2008 | 12:39 AM
rupejosh's Avatar
rupejosh
i believe your lookin and the timing advance solenoid(cold start) or the fipl
Old Dec 14, 2008 | 06:57 AM
Lazy K's Avatar
Lazy K
Sounds like the vacuum modulation valve which supplies vacuum to the C6 auto trans depending on throttle opening. If you do a search here there is a post describing how to test it with a vacuum gauge. However the first requirement is for your engine driven vacuum pump to be good and put out around 18in of vacuum.
Old Dec 14, 2008 | 01:05 PM
1545mike's Avatar
1545mike
Thanks the connector for the vacum line is broke off that is why I needed to know what it was.
Old Dec 14, 2008 | 01:55 PM
Lazy K's Avatar
Lazy K
No problem. Good luck.
