93 250 5.8l
Old Dec 13, 2008 | 11:17 PM
jellybean66's Avatar
jellybean66
93 250 5.8l
At idle speed, what would cause the engine to lope and at the same time the voltmeter will pulse from about 13 to 17?
Old Dec 14, 2008 | 05:05 AM
Opossum's Avatar
Opossum
A bad alternator/voltage regulator
Old Dec 14, 2008 | 02:31 PM
jellybean66
Thank you. Wanted to confirm what I had suspicion of.
Old Dec 14, 2008 | 06:12 PM
Conanski's Avatar
Conanski
I doubt the 2 things are related actually.. but who knows. Lopey idle on these things is ofen related to a dirty IAC valve and/or weak spark. If the alternator has a bad regulator the voltage will always increase with rpm.. which should be pretty obvious.
Old Dec 15, 2008 | 04:14 AM
Opossum's Avatar
Opossum
Voltage should still never go over 14.5, so many of the sensors are voltage sensative that such a big swing in voltage could be playing havoc on them, noy to mention the huge variation in drag on the engine. Bottom line he has a bad voltage regulator, which on his truck is internal with the alternator. The lopey idle will probably go away when the regulator is fixed if not he can then address that but the alt needs to be fixed first.
Zip
British Columbia
Sep 30, 2008 02:10 AM
AzBlueWolf
Arizona Chapter
Apr 25, 2008 01:01 AM
Bdox
18
Jan 20, 2008 10:29 AM
04SilverSCFX4
2004 - 2008 F150
May 29, 2005 10:24 PM
