X-codes?
Old Dec 13, 2008 | 03:30 PM
HKusp's Avatar
HKusp
X-codes?
I was underneath the truck today, changing my oil over to the beautiful green colored Schaeffers brand series 9000 full synthetic and I noticed a yellow X on the end of my front leaf springs. I took a pic but you can't make the X out too well. Trust me it's right there stamped in the middle of that yellow dot.
Are these the fabled X codes on my truck or what?
Old Dec 13, 2008 | 07:52 PM
tjc transport's Avatar
tjc transport
i ain't rite
an easier way to tell if your truck has X code springs from the factory is to look at the warranty sticker on the B pillar. it will tell you what your springs are.
Old Dec 13, 2008 | 08:04 PM
DCSpecial's Avatar
DCSpecial
I agree at looking at the sticker.
By "SPR" the first letter will be X if you have X-codes.
Or "Front GAWR" will be 6000lbs if you have the X-codes.
V if you have the V-codes which are 5200lbs, U if you have the U-codes which are 4800lbs, etc..
Not sure the X codes are really fabled as they are on my 99, 00, 02 and 04
Old Dec 13, 2008 | 08:26 PM
HKusp's Avatar
HKusp
Yeah, fabled was the wrong word choice, just the word that came to mind, and it was something that I thought I might like to upgrade to at one point.
Old Dec 13, 2008 | 08:27 PM
jdecker88's Avatar
jdecker88
Cold you use X codes to give a little bit of a lift in the front and how much do they run?
Old Dec 13, 2008 | 08:44 PM
DCSpecial's Avatar
DCSpecial
Yes, they do sit the tallest of all the stock leaf springs.
Not sure on cost...I thought they were fairly cheap (under $200), but I'm not sure.
Ed the partsguy may be able to help with price.
Old Dec 13, 2008 | 10:03 PM
HKusp's Avatar
HKusp
It originally must have had V codes because it says 5200lbs in the front. But that yellow dot definitely says X in the middle. Maybe the PO upgraded.
Old Dec 13, 2008 | 10:50 PM
jdecker88's Avatar
jdecker88
He might have upgraded them due to putting in the snow plow. I need to replace my springs since my bushings have went out.
Old Dec 14, 2008 | 11:06 AM
DCSpecial's Avatar
DCSpecial
I'll have to look at one of my trucks with the x-codes and see if they have an X.
