UVC connectors
Old Dec 12, 2008 | 09:33 PM
zavierbr's Avatar
zavierbr
Arrow UVC connectors
Hello,
I was wondering if someone on this forum could asist me in locating my UVC connectors? I notice a slight hesitation in my psd and would like to start with the UVC connectors.
Old Dec 12, 2008 | 09:43 PM
HookedOnFuel's Avatar
HookedOnFuel
UVC = under valve cover.
Old Dec 12, 2008 | 09:45 PM
clintbonnie's Avatar
clintbonnie
They are located under the valve covers, near the top of the head.. You can also ohms check them from the outside of the covers, without removing them.. suggest you have your fault codes read.. See my gallery for pic's of UVC connections.. Your hesitation is probably caused by something else however.. Give us some more info...
And Welcome to the forum
Old Dec 13, 2008 | 10:45 AM
F350-6's Avatar
F350-6
Welcome to FTE. Fill us in on your slight hesitation. Is it a skip or rough idle, or do you notice it while driving too? Do you have a check engine light? Have you had the CPS recall done? The new CPS has been known to cause a rough idle.
Old Dec 13, 2008 | 11:36 AM
joegebff's Avatar
joegebff
Gone Fishin for Mark
Welcome to FTE.
I agree that if your only problem is a slight hesitation it is probably not a UVCH problem.
Give us more info.
Old Dec 14, 2008 | 05:37 PM
zavierbr's Avatar
zavierbr
I change my fuel filter today and the hesitation still there. I will be buying a new cps next from usedieselparts.com ($25) and hoping that may cure this problem. I havent had any check engine light coming on, so I hope this is something simple. Where in the engine compartment is the cps located?
Old Dec 14, 2008 | 05:44 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Have a look at this, should be all you need to know. click here
Andy Sullivan
Aug 12, 2013 09:21 PM
zavierbr
Dec 23, 2008 08:34 PM
MR5x5
Oct 28, 2007 12:22 PM
zstyle01
Apr 17, 2007 07:03 PM
PA_Ford_Man
Jan 24, 2007 10:16 AM
