Starting Issues
Old Dec 12, 2008 | 06:58 PM
BlueOval390's Avatar
BlueOval390
Starting Issues
Ok I've got a '73 Ford F-100 with 390 and a Holley 4bbl and I had the carb rebuilt a few months back. Got the carb back and put it back on and turned the key and it fired right up. Idled high becuase it hadn't been tuned yet. Turned it off and came back to it a month later and nothing. It would not start. Is it possible that the fuel pump went out or bad fuel. I replaced both fuel filters a few days ago.
Old Dec 12, 2008 | 08:33 PM
Redmanbob's Avatar
Redmanbob
Prime it and try it. May just need a kick start.
Old Dec 12, 2008 | 11:43 PM
BlueOval390
Starting problems
Prime it? If you are referring to pouring gas down the carb before starting, did that it runs for a few seconds then shuts off again.
Old Dec 13, 2008 | 12:45 AM
Bear 45/70's Avatar
Bear 45/70
Try tapping the needles on the carb float bowls with a plastic screw driver handle. You may have stuck floats.
Old Dec 13, 2008 | 10:25 PM
BlueOval390
Starting issues
Good call Ill check it out tmmrw
Old Dec 15, 2008 | 09:24 PM
BlueOval390
Starting Issues
Would having a stuck needle/floats keep my carb from getting fuel?
Old Dec 15, 2008 | 10:02 PM
Redmanbob's Avatar
Redmanbob
If it runs when primed but wont stay running. Bears advice on the floats is good quick check. Might try confirming the pump is pumping, remove the line from the carb and put it in a bottle and crank the engine over. If none or a very little fuel makes it through, the pump may be bad or air getting into he line, or maybe it's drawing a vacuum pull the fuel cap and listen for pressure release.
Old Dec 16, 2008 | 12:15 AM
BlueOval390
Starting issues
Yeah it sounds like I got a stuck needle or something with the floats, thanks for the help
trat3gic
Jan 6, 2016 04:15 PM
jas88
Jul 13, 2015 10:56 AM
1975F2504X4
Jun 14, 2015 07:25 AM
08gasurveyor
Feb 6, 2013 03:48 PM
edsf100
Jun 10, 2005 09:28 AM
