EBAY listing
Old Jan 1, 2009 | 02:31 AM
  #46
orng1's Avatar
orng1
Originally Posted by jdecker88
Stage ones? How about some hybirds?
A friend of mine built them for me at his work. He can't do to much but he did turn them up for me a bit. 4 of them were bad other wise I would have waited to have some money, since I didn't I had to do what I could.
Old Jan 1, 2009 | 09:06 AM
  #47
jdecker88's Avatar
jdecker88
Four of them was bad? was they all on the same side? If thats the case you probably have a bad harness under your VC.
Old Jan 1, 2009 | 12:06 PM
  #48
orng1's Avatar
orng1
They were on different sides, I replaced the harness early this yr. Well last yr.
Old Jan 1, 2009 | 12:17 PM
  #49
jdecker88's Avatar
jdecker88
That would be a good reason to get a new set, hopefully he builds them good, is your #8 injector bad?
Old Jan 1, 2009 | 12:19 PM
  #50
orng1's Avatar
orng1
There in the truck already, the truck runs good. Real good.
Old Jan 1, 2009 | 12:21 PM
  #51
jdecker88's Avatar
jdecker88
Great to hear how hard was it? Was you #8 injector bad I am asking because mine is getting weak and I am needing one.
Old Jan 1, 2009 | 12:25 PM
  #52
orng1's Avatar
orng1
Yes it was, from when I first got the truck it did a sort of wait til I warm up deal. It would take a while to get power. I thought it was the hpop but it was the injectors. I waited because I didn't want to repair one injector, I wanted an upgraded set. Unfortuntely it didn't let itself wait until I had any real money, as always happens.
Old Jan 1, 2009 | 01:00 PM
  #53
jdecker88's Avatar
jdecker88
I would love to throw some better injectors in mine but I am real tight on money How much did it run you?
Old Jan 1, 2009 | 01:06 PM
  #54
orng1's Avatar
orng1
$1200 but there were other problems with my truck at the same time that needed to be repaired. If it were just the injectors it'd been 3-400 less.
Old Jan 1, 2009 | 01:17 PM
  #55
jdecker88's Avatar
jdecker88
Not to bad for stage ones.
Old Jan 1, 2009 | 01:19 PM
  #56
orng1's Avatar
orng1
Not just that he rebuilt all 8 and then upgraded them, this set should last me a llloooonnnnnngggggg time.
Old Jan 1, 2009 | 01:32 PM
  #57
jdecker88's Avatar
jdecker88
If he is that good then i might need to send mine that way . Besure to tell Jody about it all.
Old Jan 13, 2009 | 12:26 AM
  #58
orng1's Avatar
orng1
Not really an ebay item, I found it on craigslist in los angeles area. Simi Valley.
Old Jan 13, 2009 | 12:27 AM
  #59
orng1's Avatar
orng1
Oh yeahm the link would help.
1999-04 FORD PU TELESCOPING
Old Jan 13, 2009 | 03:06 AM
  #60
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
$150 for both is a steal... wanna say i paid 139 for a used one a couple years back.. Man i'm gettin old, i can say "couple years back" for the truck now :-(
