Staring Problems!
Old Dec 11, 2008 | 07:40 PM
BlueOval390's Avatar
BlueOval390
Staring Problems!
I posted last wee about the issue I was having with my '73 Ford F-100 and not being able to get it started. At first I thought it might have been the fuel pump and checked it and it was pumping gas, replaced fuel filters still nothing. Now the carb was rebuilt a couple months ago and I had been having trouble with the front adjusting screw on the carb with gas bubbling out. Its a Holley 4160 getting a little frustrated. Any help would be appreciated.
Old Dec 12, 2008 | 12:32 AM
masterbeavis's Avatar
masterbeavis
FRONT adjusting screw? Its not a 4160 if it has front mixture screws, its a 4180. Are you talking about the screw on the top of the float bowl? That is the float bowl adjustment/needle and seat. Whack the thing with a hammer(GENTLY) to dislodge the crap keeping the needle and seat from sealing. You can take the needle and seat out to clean it. Pull the float bowl site screw off and see if gas pours out. The fuel level should be at the very bottom of the screw hole, and nothing should come out.
If you have gas coming out of the bottom of the carb, you have some issues. Either a blown power valve, or an internal leak of some sorts. Can you post a picture of where the gas is coming from?
Old Dec 12, 2008 | 02:29 PM
Alvin in AZ's Avatar
Alvin in AZ
My pickup has that problem too. :/
I've managed to get by with just explaining to people upset by it...
"I'm sorry, but my pickup's retarded and it didn't mean anything by it staring at you"
...and so far got away without any fistfights.
I truly believe it's their problem tho, I mean, why are they so paranoid about
being stared at by a junky old pickup anyway?
Alvin in AZ
ps- anxious to see what your carburetor trouble turns out to be :)
Old Dec 12, 2008 | 03:24 PM
brooklyn's Avatar
brooklyn
I have the opposite issue. People keep staring at my truck. Wouldn't consider it a problem, though.
Also have nothing really useful to add, but am subscribing as I too have Holley carb adjustment issues (albeit different ones).
Old Dec 12, 2008 | 03:41 PM
Alvin in AZ
LOL :)
Yeah. :)
I just like to learn stuff and that's my back-handed way of subscribing. :/
I want him to do everything Beavis told him to except hitting it "gently"
(or any other way) with a hammer. LOL :)
...if the fuel flowing through it and with the float bobbing up at the same
time (normal driving) won't dislodge the debris...
But if there is debris in the float valve seat... then the bowl is prob'ly full
of it and the sucker needs taking apart anyway. IMO ;)
ButtHead in AZ
Old Dec 12, 2008 | 06:04 PM
BlueOval390
STARTING problems
yeah I know my spelling was off but anyhow, just don't know what is going on it is possible that it is the pump but there is fuel in the line from the pump to carb? Also it could be a choke issue?
Old Dec 13, 2008 | 03:53 AM
myv-879's Avatar
myv-879
I don't have any problems with my holley anymore as it is now sitting on my bedroom floor!
