High idle missing shift points
Old Dec 11, 2008 | 05:22 PM
BNeu11383's Avatar
BNeu11383
Thumbs down High idle missing shift points
I just got a free 1993 F150 and the problems wont stop. Biggest problem im having is im getting a high idle and missing shift points. When i start it up, it is fine untill i get about 3 miles down the road and then the check engine light goes off, transmission seems to drop down a gear and wont shift and idle is at about 2500 in park and in gear 1600. My shift points only seem to be at 30 and 60. when i unplug the IAC it idles back down to about 900 but kinda wants to die at stop lights and still not shifting right. Looked at vacuum lines but didn't find any broke.
At the start of this project i had the same problem replaced the temp sensor, plugs and wires and put on a use IAC and everything worked great for about 1 week. Could dirty or old coolant cause the temp sensor to go bad? Truck was sitting for 2 years before i got it. Cleaned both IAC and doesnt help either.
Please help i get my license back in one week and cant wait to drive this beast!
-B-
Old Dec 11, 2008 | 05:39 PM
alxsnmr's Avatar
alxsnmr
Sounds like you need to clean the IAC as a beginning point, then off to replacing vaccuum lines one at a time. You have the dreaded high idle that takes time to fix. But your tranny is a wholely different issue.
Old Dec 11, 2008 | 07:41 PM
brrossi's Avatar
brrossi
Sounds like a bum TPS. Had one go on the 88 I use to own. Ruffly the same symptoms.
Sais13579
Oct 24, 2024 04:22 PM
DBGrif91
15
Jan 20, 2014 04:58 PM
bcboy4ca
22
Mar 10, 2013 09:38 PM
charlieranger
1983 - 2012 Ranger & B-Series
13
Aug 8, 2012 11:21 AM
gdolson
1997 - 2003 F150
Oct 22, 2002 08:25 PM
