No Muffler??
No Muffler??
We have the V10 6.8L in our '03 Excursion and when we looked at the exhaust wand notice it wasn't welded . So we experimented by unbolting the last half of the exhaust so the cats are still on, and we like the sound better than the flow masters. And we went to radio shack and borrowed their decible meater. It was 98bd under the truck and legal is 92 bd, so as far as loudness goes we shouldn't have any probs for being to loud. So my question is how is the performance affected by having no muffler on the truck and what is it affecting, like horse power, torque, gas milage, and what ever else you can tell me. Thanks!!!
As long as you keep the Diameter down and the same length as stock, you shouldn't have any significant negative effects. If you increase the diameter of the pipe, it will change it's resistance to airflow and you will either make more pressure or you will start sucking in air and slowing exhaust flow.
The muffler attenuates certain frequencies, either by absorption or by reflection. There should be minimal changes in velocities between the input and output of the muffler.
when we got our lift the guys cut our exhaust and put on a tube that is about 12-15 inches long connected to the muffler that curvered down, like what you see on trophy trucks, and our neighbor said that he could cut off the pipe from the muffler and weld it onto the exhaust if we decided to keep but i want mak sure we aren't hurting the engine and causing damage by removing the muffler. On average how much is it to get a dyno, so i can see the power diff??
