Sponsored by: Kumho
Radius Arm Bushings
Old Dec 2, 2001 | 04:49 PM
CUWaldo's Avatar
CUWaldo
Radius Arm Bushings
Truck is a 94 F150, 2WD model.
Passenger side radius arm bushing is MISSING. Anyhow, I replaced the bushing.
The drivers side bushing is fine. My question is should I replace it anyway? The new bushing came as a kit, with parts for both sides. I can only imagine they're a little bit different from the OEM ones, so it will probably mess up my steering geometry if I don't replace the drivers side as well.
Comments??
Thanks,
Tim
Old Dec 2, 2001 | 11:16 PM
Ryan50hrl's Avatar
Ryan50hrl
Radius Arm Bushings
You should always replace bushings in pairs. Theres probably a reason why the bushing was missing, like it was dry rotted or cracking out. not to mention your right, it could space one side of the axle forward.
Ryan
1995 F-150 supercab
6" Skyjacker Class II softride lift
skyjacker Nitro shocks
35" BFG Mud Terrains KM
Old Dec 2, 2001 | 11:36 PM
NoMo's Avatar
NoMo
Radius Arm Bushings
I agree- replace both bushings and have the truck re-aligned.
I think the passenger side fails (and always will) first because it is too close to the exhaust system. The heat-cycling just kills the rubber.
Old Dec 3, 2001 | 09:14 PM
CUWaldo's Avatar
CUWaldo
Radius Arm Bushings
Thanks for the inputs. I was leaning on replacing them both anyhow, now I'm sure of it.
Thanks,
Tim
Old Dec 4, 2001 | 12:42 PM
thomasr's Avatar
thomasr
Radius Arm Bushings
