The Louisville Line Trucks and What They Replaced
Ben, thank you for the rather comprehensive list. From what you have and looking around at a few truck listings I've noticed a couple of things:
1. Because of the weight rating, all 9000 models had tandems and there should be no 7000 tandems.
2. Hoods seem to be somewhat evenly split between the L and LN, with more long hoods when stepping into a tandem rear end.
3. A large percentage of the people that list their L series on truckpaper.com have no idea of what they have. LS's were listed as L's, LNT's listed as L's, etc.
As a quick follow up, what was the difference between the hundred and thousand series (e.g. 900 vs 9000)? Also, what were all the grill types and in what years did they change styles?
So does that mean the 1160 and the 3208 are indeed different engines; and that the 636 cubic inch displacement and V-8 configuration are the only things these two engine models have in common???
~Ben
Hmmmm, that sucks. I've heard different tales about the 1160/3208 engines. I heard, from several truck mechanics, that the 3208 was the boat anchor, and the 1160 was ok, for light to medium truck use, but not to lug it, as it could break the crank. Oh well, it works great for what I am doing.
Now, for a more serious question. I need to id the tranny I got. I know it's a 5 speed main box, and the auxilliary is a Spicer 4 speed (2 under, direct, and over). I initially was under the impression, that the main was also a Spicer, but after looking through the books at work, I don't think so. The tag is gone, and I can't find any thing to positively id it, and I need to get a clutch release bearing for it. Any thoughts? There are some pictures of it in my photobucket album.
~Ben
a good portion of the trucks had fuller transmissions,think spicer was a second choice behind diesel engines
Truck should have a lipe two plate clutch if so the would be the same for both transmissions,spicer did also make a 2 plate clutch for them
Ray, 3208 engines didn't use sleeves either. The only type of sleeve they ever got was a pressed in repair sleeve that requires machine work and a large press to install. Both engines used cam bearings. They also share the same bore and stroke.
~Ben
Thanks for the help guys. Ben, it is the Spicer 6352. I googled it, and got some very clear photos, and compared them to mine. Since it's the direct in 5th, it's the 6352, if it were OD in 5th, it would be the 6353, from what I saw, is that right? I looked up the release bearing on NAPAs web site, and will have it ordered tomorrow. So, with a three day weekend coming up, I'll actually have time to r&r the trans for replacing the rear main, and the release bearing. I'll also try and get the dealer plate, so I can make a film of me driving it, so I can share it with the FTE gang. I guess I'm not too concerned about 1160s or 3208s, and what not, since I know this thing runs great (aside from the rear main), and more than enough power and torque to work for my needs. I mean come on, it has as much horse power as a turboed 5.9 Cummins, in stock trim, and the Ford Power Stroke, and more torque than either one. So, I can't complain, especially since I can still get everything I need for it in the way of repair parts.
My next Big Job build is going to have either a Cat straight 6 (aint decided witch one yet) or a Cummins. It'll be getting full air ride, and a sleeper. For this day cab, the 1160 is perfect, and will make selling it easier when done. I am also kind of interested in the new International Maxx Force line. They look to be a pretty nice engine, and one of our customers has one in his single axle tractor. It seems to be plentiful on power, and runs very smooth and reasonably quiet for a larger diesel. I like these Louisvilles though. They are the perfect donors for the older big trucks. The frames are the same width, and all the important stuff is danged near in the perfect spot for adapting the old bodies on to them.
The "Louisville Line" also included the "C Series" Cabover truck. Those little "Box" cabbed trucks were used by Roadway , and was used for a few Firetruck platforms. The Louisville plant also built the Ford Cargo truck there too! I worked for a trucking company here in Louisville hauling the Crewcabs for the F-250/350 trucks! In 1997 , got to watch the "LAST" Ford Aeromax come down the line, Truck got a lot of signitures as it went by. As it cleared a section of the assembly line, Abel Construction took out the line! It's where the Excursion was built on after that.
#29
#30
BTW, I checked out your Big Job pics. Nice work.
