Spade terminal on starter
Old Dec 10, 2008 | 08:39 PM
manger's Avatar
manger
The search option is giving me errors, so let me ask the question here. Lately, after the 1992 F-150 has been sitting outside for a day in the cold (19°) and snow, I jump in to start it and it either sounds like a dead battery (really slow crank), or no crank. I climb under the truck, remove the wire at the top of the starter, put it back on and it starts right up. I seem to remember reading about this terminal being a typical problem. Do I need to remove the starter to replace this? Or should I cut the wires on the female connector and replace it? I cannot see from underneath the truck as to what the problem is. Not sure if it is corroded or what.
Old Dec 10, 2008 | 08:51 PM
quicklook2's Avatar
quicklook2
new starter come without the spade.
i find cleaning them with a wire brush and crimping it once a year has helped.
or replace the starter.
Old Dec 11, 2008 | 01:32 PM
manger's Avatar
manger
Thanks a bunch quicklook! I will have to give that a try. Its been happening more often.
Old Dec 11, 2008 | 01:51 PM
straightsixer's Avatar
straightsixer
What is the function of this 'spade connector'?
Old Dec 11, 2008 | 02:28 PM
quicklook2's Avatar
quicklook2
part of the connections that power the starter.
