95 F250 headlight switch repl.
Old Dec 10, 2008 | 06:24 PM
Harley05Ultra's Avatar
Harley05Ultra
I'm trying to replace my headlight switch. Can anyone tell me how the gauge cluster trim comes off? It feels like it just pulls off but from past experience I thought I'd try for a heads up first. As always, thanks ppl Ed
Old Dec 10, 2008 | 06:35 PM
ron86toy's Avatar
ron86toy
IIRC There are a couple screws above the steering wheel.....and you need to pop off the trim pieces on the front to access some screws
Old Dec 10, 2008 | 06:42 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Gently pry the trim pieces on each side of the steering wheel mounted in the dash bezel. Remove one screw underneath each. Remove the plastic headlight **** from switch stem (there is a notch in the back side of the ****, use a small tool having a 90* bend on the end of it, like a small Allen wrench, to pull a metal spring tab toward you while pulling on the ****). Tilt steering wheel down. Gently but firmly pull the dash bezel from dash. You'll need to disconnect the fuel tank switch on the left and a small gauge cluster on the right (and possibly any mods mounted in the bezel) as the bezel comes away from the dash.
