Narrowing driveline vibration down
Old Apr 4, 2009 | 08:37 PM
dave91gt's Avatar
dave91gt
Thanks for revising the thread. I am still fighting the vibes. The new V codes and rear 350 blocks made the ride much better and looks awesome. I have tried indexing the driveshaft all over the place. It changes the vibration somewhat but it is still brutal. I went through everything again (even considering a new $400 shaft from Ford). But, I may be onto something. The rear bearing in the transfer case has up and down and in and out movement. That may be the source. Ford wants $40 or so for the bearing and hopefully it is easy to change. If it doesnt fix it, I am buying a driveshaft. I was going to try a 30,000 mile driveshaft out of an 05 F250 but it is too long. That shaft had a big balancing ring on the pinion side and the slip shaft had more play than mine. Hope to get to the bearing this week. Any input on changing the bearing?
Jointasset
Jul 5, 2016 08:24 PM
Superduty.pride
1978 - 1996 Big Bronco
Mar 2, 2016 03:16 PM
TonyJestis
15
Nov 5, 2012 06:13 PM
dave91gt
Jun 15, 2009 11:23 AM
fd1109
13
Dec 5, 2007 06:32 PM
