hello all i am new to this site i am a big fan of mustangs and just got a good truck to pull them with its a 00 f150 7700 4 wheel drive i was wondering how much trouble it would be to put oem fog lights on this truck i know i would have to change the front valance but is all of the wiring there or will i have to wire it all in
thanks for any help
well to do a complete oem style it would be difficult since the wires arent pre run. New headlight switch, relays. Theres a lot to the oem style. But if you just used the oem lights and valance and hooked them up to a separate switch on the dash it wouldnt be to bad.
Wire the fogs to a relay that has power, and then run wires into the cab from the relay to a switch on the dash.
howdy l placed fog lights on my 2003. on my truck the wires plugs were there in the front,take a look? if there there? you'll a valance, l got the lights
on ebay and light switch yl3z-11654-bab which is dealer item the extra light
they give makes a big diffrence plus that sporty look
