Freaky Speedometer
Old Dec 11, 2008 | 03:05 PM
Jaaaaaaackman's Avatar
Jaaaaaaackman
might not be related to your speedo problem , but I had a bounceing needle totally unreadable , not sure if the odometer was acurate but the problem was the sensor under the ring gear in the rear axle,,,,,,,,,, put a new one in and speedo is as should be......... I had a previous rear gear axle problem which in turn wrecked the speed sensor......
Old Dec 11, 2008 | 03:41 PM
Action4478's Avatar
Action4478
Originally Posted by madpogue
But I'll bet when you got yours fixed, the odometer didn't account for the interim miles driven, right? THAT's the key. The OP said when her/his odo came back, the mileage had increased. That indicates a good signal from the VSS to the PCM (I THINK).
I never looked at the odo...
Old Dec 11, 2008 | 11:37 PM
IDMooseMan's Avatar
IDMooseMan
Originally Posted by superduty4x4
Craig- does the speedo bounce at all, or does it just quit? If it just plain quits it might be wiring like Rick said. When my PSOM quit me, it quit me once going down the freeway between Twin and Boise... just flat quit for a few miles then sprang back to life after I thumped the dash a few times. Went along fine for a week or so, then I started getting a bouncing speedo, and I mean REALLY bouncing- would go from 40 to 70 at around 65 mph. Definitely check the wiring before you go spending $ on parts. It also wouldn't hurt to pull the VSS out and wipe it off to see if that helps.
I plan on cleaning the VSS. No bounce in the speedo/odo, needle just drops and odo blanks out.
Old Dec 11, 2008 | 11:49 PM
IDMooseMan's Avatar
IDMooseMan
Did you replace this yourself? What is involved in doing this?
I have a non-limited slip differential. If it has to be removed or rebuilt, I'd probably go with a limited-slip unit just for the heck of it. I would think it would be much of a cost difference between rebuilding the non-limited slip unit versus installing a limited-slip unit.
I wouldn't be able to this myself. I'd hafta take it to the dealer or some other shop.
Old Dec 12, 2008 | 09:07 AM
madpogue's Avatar
madpogue
Originally Posted by IDMooseMan
Mcdavidson, Veerrry funny. Thanks again for the help with the GPR "testing". PEBWAP, huh...is that like a "keyboard" issue causing computer problems?
We like to say that "the problem has been isolated to between the keyboard and the chair"...
Old Dec 12, 2008 | 11:29 AM
mcdavidson's Avatar
mcdavidson
Ah Correct MadPogue!
And If you had ever met Craig, you would agree on PEBKAC...
So, I translated the acronym it into AutoSpeak....
HOWEVER I don't know that I would be surprised to be driving down the road and look over to see Craig driving down the road with a keyboard on his steering wheel trying to type something into the FTE forums! (Or the ITD forums)...
Old Dec 12, 2008 | 01:55 PM
Hussler's Avatar
Hussler
Since no one has mentioned this when it happens wiggle the ignition switch and see if the odometer lights back up. As the truck ages going from RUN > START then releasing the key sometimes the it will not go all the way back to the RUN position. The Key has to be in the RUN position for the odometer and the sped-o to function, ie (light up).
Old Dec 12, 2008 | 09:50 PM
Jaaaaaaackman
Mooseman, I sent the truck to a heavy truck repair shop , the speed sensor was actually a freebe on them, the whole story is that back in Feb 08 I busted 3 teeth on the Dana 70 ring gear while plowing snow the shop next day aired my parts got me up and running in 3 days, the speed sensor problem was imediate but being a work truck I did not bring it back right away cause I work with the truck every day . It was a lot of work for them but they said that the speed sensor should have been ordered with the ring gear but they thought it was good to go, total cost was 1323.00 dollars I thought was not bad considering the ring gear and next day aire charges was around 300 dollars.......
BTW I bet your speedo problem is else where and not related to the rear axle, I only mentioned it cause these trucks are so much more complicated than they use to be and it nice to gain more understanding on how things work, the speed sensor was a new learning thing for me too....
Old Dec 12, 2008 | 09:52 PM
IDMooseMan's Avatar
IDMooseMan
I've used this explanation at the office several times. We simply call it a "keyboard" issue.
Also, there are 10 types of people in the world, those that understand binary and those that don't.
Old Dec 12, 2008 | 09:56 PM
IDMooseMan's Avatar
IDMooseMan
MIIIIIIIKKKKKKKKKKE! That's it, I'm putting down my keyboard, parking the truck and getting my shovel.
You even changed the acronym this time. How am I supposed to keep up?
Old Dec 12, 2008 | 09:57 PM
IDMooseMan's Avatar
IDMooseMan
I'll have to give this a try the next time it happens...and I'm sure there will be a next time.
Tried to rep, but you know the story. Gotta spread the love around first.
Old Dec 12, 2008 | 10:02 PM
IDMooseMan's Avatar
IDMooseMan
Thanks for the insight and a different perspective on this issue. Reps sent.
Old Dec 13, 2008 | 12:38 AM
  #28
madpogue's Avatar
madpogue
BTW I bet your speedo problem is else where and not related to the rear axle,....
Once again, if the odo is accumulating, even when it's not displaying, the VSS is (most likely) good.
Did you know that Halloween equals Christmas? Yeah, OCT 31 = DEC 25 .
Old Dec 13, 2008 | 01:19 PM
  #29
IDMooseMan's Avatar
IDMooseMan
Haven't heard this one. Please explain. A new learning opportunity for me arises once again.
Old Dec 13, 2008 | 06:02 PM
  #30
madpogue's Avatar
madpogue
OCT (Octal, or base 8) 31 = 3*8 + 1 = 25 = Decimal (DEC) 25
