need help with a Fluids Engineering problem
Old Dec 9, 2008 | 09:17 PM
Jimmy Dean's Avatar
Jimmy Dean
I need to derive the formula for a rotating cylinder viscometer neglecting end effects.
I know the formula:
T=torque
w=rotational velocity in rads
L=depth of fluid
u=viscocity
R1=radius of rotating cylinder
R2=radius of fixed outer cylinder
Formula:
T=4*(pi)*w*L*u*[(R1^2*R2^2)/(R2^2-R1^2)]
I just cannot figure out how to derive the dang thing.
Old Dec 10, 2008 | 07:51 AM
Nitramjr's Avatar
Nitramjr
The formula looks a little strange since it is solving for Torque. Wouldn't viscosity be your only unknown?
The hard part will be getting all your units in order and cancelling out those you don't need. It looks like all the formula involves is a difference in surface area between the cylinders, a difference in volumes (L is a common factor in these, as is pi), the rotational speed (radians per second) and the torque (newton-meters?). It doesn't look to be that bad.
Slow day at work today, let me see if I can make this work....
Cruiseomatic
23
Sep 14, 2013 01:22 AM
cjben
May 14, 2013 09:55 PM
captain p4
Mar 9, 2008 07:34 PM
