Sponsored by: Kumho
95 Factory Rims??
Old Dec 28, 2001 | 05:25 PM
curtie1107's Avatar
curtie1107
Post 95 Factory Rims??
Can I put wider or bigger tires on my factory rims for my 1995 F150 2 wd? And if so how wide can I go? I dont want new rims right now because the factory ones are still in great shape? I am just tired of my little skinny tires on my truck. Thanks.
Old Dec 28, 2001 | 05:57 PM
StrangeRanger's Avatar
StrangeRanger
95 Factory Rims??
Which rims do you have? 7" or 7.5"
Old Dec 28, 2001 | 11:04 PM
MustangGT221's Avatar
MustangGT221
95 Factory Rims??
If you don't know, Pull off a rear tire and look on the inside of the rim (rear because theres to much brake dust on the fronts) it will tell you what size you have. It might say it on the door jam i forget. If you have 7.5 in rims, you can get any tire up to 11.5 wide as the limit.
Old Dec 30, 2001 | 06:56 PM
canadianfordman's Avatar
canadianfordman
95 Factory Rims??
You can't get an 11.5 on a 7 rim can you. I am selling my 32x11.5x15 tires because I only have a 7 inch wide rim but if they will fit I will sell my 31x10.5x15's instead.
Old Dec 30, 2001 | 10:22 PM
MustangGT221
95 Factory Rims??
I would say they will fit but it is pushing it. An 11.5 inch wide tire has a recommened minimum width of an 8 inch rim, so a 7.5 is close enough, no experience with it. I've heard people put 12.5 inch wide tires on a 7.5 inch rim so i think you should be ok.
Old Dec 31, 2001 | 02:07 AM
canadianfordman
95 Factory Rims??
Yeah I think I would be fine. I have a set of 31x10.5x15 that are mounted on 7 inch rims and they rub when I turn all the way. I am not sure of the backspacing on the rims, they are the grey ones with the center cab and beauty ring from 86-91. When I put the 32x11.5x15 which are mounted on 15x8's they don't rub at all. If I was to put the 32's on the 7 inch rim then I believe they would rub like crazy. Thanks for the help though.
Old Jan 2, 2002 | 10:10 AM
traildawg's Avatar
traildawg
95 Factory Rims??
Culvert
Crossovers
Aug 22, 2014 01:07 PM
jkuelper
Mar 3, 2011 03:35 PM
the Goat
Aug 27, 2010 10:35 PM
2000gpr
2004 - 2008 F150
Apr 9, 2008 09:56 AM
turbostroke
2004 - 2008 F150
56
Oct 15, 2007 09:24 AM
