Will this oil pan work?
Old Dec 9, 2008 | 12:58 PM
460's Avatar
460
I'm swapping a 5.0 HO into my '79 F150 2wd. Will the oil pan in the pics below work with my truck? Note the location of the starter and oil filter to determine which end is front/back.
Does anyone have a good picture (hopefully from the same angle as mine) of the stock oil pan on a 302 2wd truck?
Old Dec 9, 2008 | 02:22 PM
79f150toy's Avatar
79f150toy
it appears it would work, I think you would have problems if it was a front sump pan from a car(of the same vintage). I used a front sump pan on my 70 2wd w/a 429. it was a real pain to get to the drain plug, so I relocated it... but I think for the most part, truck oil pans are rear sump...so you should be golden...
Old Dec 9, 2008 | 02:44 PM
Ronzi's Avatar
Ronzi
That pan appears to have 2 drain plugs. It might be a pain to get to that front plug.
Old Dec 10, 2008 | 11:48 AM
460's Avatar
460
Thanks guys, and yes it does have 2 plugs. I'll check the clearance of the front plug before I drop the motor in.
Old Dec 11, 2008 | 11:13 AM
loudfords's Avatar
loudfords
2wd trucks were front sump up to 79, but the rear and double sump pans will fit ok without hitting tie rods.
Alcaeus
40
May 26, 2015 11:05 AM
boulderguy
Aug 9, 2012 10:46 AM
460
1983 - 2012 Ranger & B-Series
18
Feb 5, 2011 12:56 AM
460
Feb 24, 2009 09:15 AM
460
Dec 25, 2006 12:39 PM
