Sponsored by: Real Truck
Fuel mileage decrease when cold outside.
Old Dec 9, 2008 | 08:04 AM
kenneBF250V10's Avatar
kenneBF250V10
Does anyone else have a noticeable fuel mileage decrease when it gets cold?
I noticed it this past weekend when I was on my way back from a hunting trip in OH. In early October I made the same exact trip (same route, same speed) the only difference was the temps outside. On that trip the temps were in the 70's and I got 330 miles out of a full tank. This past Saturday when I made the trip the temps were in the 20's and I only got 305 miles out of a tank.
Nothing has changed on the truck. The only thing that did change were the conditions outside.
I'm not concerned about it but 25-30 miles less per tank of gas is quite a difference.
Old Dec 9, 2008 | 09:58 AM
PERFORMANCE RED's Avatar
PERFORMANCE RED
Yes my 07 V10 drops noticably when the temps are below 20°.
Old Dec 9, 2008 | 10:01 AM
redford's Avatar
redford
FTE Leadership Emeritus
Not only that, but if you live in one of the areas where it is mandated (THANK YOU EPA) your using oxygenated gasoline during the winter months. That alone can drop your mileage 15-20%.
Old Dec 9, 2008 | 10:04 AM
Fordsflylow's Avatar
Fordsflylow
I too think it has much to do with the formulation of the gas for winter. I've found I get better mileage from shell vs philips66.
Old Dec 9, 2008 | 10:05 AM
maytag03's Avatar
maytag03
I agree it is the winter gas you are running.
Old Dec 9, 2008 | 10:58 AM
SAlexander's Avatar
SAlexander
Engine may run a little richer for the cold starts. Maybe you let it idle more for heat or defrost? I've noticed the same with all my vehicles. Seems mileage is best in the spring and fall. No choke, no idle for heat, and no AC.
Old Dec 9, 2008 | 11:22 AM
kenneBF250V10
I figured it was probably the winter gas formula. Just wanted to make sure it wasn't just me experiencing this.
Old Dec 9, 2008 | 11:38 AM
SAlexander's Avatar
SAlexander
We have that gas all year here in NY.
Old Dec 9, 2008 | 11:47 AM
1979Mustang's Avatar
1979Mustang
My old 2002 F-250 C/C V-10 4X4 got 8 mpg in the summer and 6 mpg in the cold winter. After four years of that 6 mpg in the winter I traded it for a diesel.
Old Dec 9, 2008 | 11:56 AM
2000silverbullet's Avatar
2000silverbullet
Make sure your front hubs aren't engaged as well.
I figured if you were out hunting, you may have had the truck in 4 wheel and they may not have disengaged. Mine do this all the time and kill my mileage...
Old Dec 9, 2008 | 12:14 PM
wiingnut's Avatar
wiingnut
It's called WINTER BLEND.
Old Dec 9, 2008 | 12:22 PM
krewat's Avatar
krewat
Same here on Long Island. And I never notice a difference in my V10 between that stuff and the non-oxygenated stuff I've gotten in other states.
In reality, it's really just the COLD doing it - colder intake air means richer mixture for the engine to run right.
Just like with the old carbed vehicles, where the choke closes when the engine is cold to keep the mixture rich, EFI does the same thing.
Also, colder air means denser air - which means more oxygen in every intake stroke, which means more gas to make it stoich. WHich also means more power on tap when you slam on the gas.
Without changing driving habits to compensate, it means less mileage.
Ever wonder why some of the "miracle" gas savers that really don't work show a MARKED improvement in fleets of hundreds of trucks, but only when you tell the drivers?
Old Dec 9, 2008 | 01:07 PM
david0505's Avatar
david0505
Same here in sunny California,soon as the fall temps arrive My powerstroke (2003)loses about 2 mpg, and has since the first winter,Ford service says it's the change in fuel
Old Dec 9, 2008 | 03:52 PM
skip mitchell's Avatar
skip mitchell
as well air that is colder is much denser,so it also takes more fuel to make the 14 to 1 fuel air ratio,during cold weather.
Old Dec 9, 2008 | 07:02 PM
sarnott140's Avatar
sarnott140
My powerstroke loses 5 mpg in the winter. I'm in Canada where the summer's are hot and the winters are very cold
