Sponsored by: Kumho
rear end
Old Jan 10, 2002 | 10:24 AM
rocky50's Avatar
rocky50
rear end
how do I tell what rear end I have?
85 F150, 3-sp. auto, orig. 300/6, 3.08 ratio.
do you count the bolts on the rear cover or what?
Thanks,
Meaux
Old Jan 10, 2002 | 10:57 AM
MustangGT221's Avatar
MustangGT221
rear end
If you look at the sticker on the door jam under "axle" it gives you a letter and you can use that i believe, but since its a 150 i would say its an 8.8 inch ford, thats what i have.
Old Jan 10, 2002 | 02:20 PM
canadianfordman's Avatar
canadianfordman
rear end
[updated:LAST EDITED ON 10-Jan-02 AT 03:20 PM (EST)]After 83 they only put the 9 inch rear ends in the F150's with a 351 High Output. I have an 84 with the 9 inch and the 351 HO and 2 86's with 302's which are both the 8.8's. If there are bolts holding on the diff cover then you have the 8.8 if not it is the 9 inch. I am 99% positive it is the 8.8 though.
Old Jan 11, 2002 | 07:10 PM
slimersoup's Avatar
slimersoup
rear end
