I have a 91 150 4x4 w/ 302. I have the single shock front setup and need some new stiffer front springs. Now heres the fun part...it has a 6 inch lift. any ideas?
If you're not on a tight budget National Spring will custom make springs, coil or leaf for any application. Obviously they will not be as cheap as off the shelf but I don't think their prices for custom springs are too bad. The easiest way to find contact information for them would probably be to get a copy of Four Wheeler magazine and look for their add in the back of the magazine.
Just outta curriosity does anyone know if 32's will fit on a 92 F-150 4x4. I just got a 2" front coil spacer kit from daystar and the existing 31's look small. Here's the problem, the 31's rub on the radius arm enough to leave a 1" mark so I dont know if the 32's will cause any major damage, thanks for any help.
I just put new springs in the front of my 86 F150 and it sits high. I put 32's on to replace the exisiting 31's and they fit great. The new rims have a 3.5 inch backspacing so they don't rub like the 31's did. Hope this helps
