Sponsored by: Kumho
Simple Leaf-Spring removal question
Old Jan 23, 2002 | 01:54 AM
GammaDriver's Avatar
GammaDriver
Hello there.
I just got a rear leaf spring bushing kit from Energy Suspension, but I was wondering about possible upcoming heaaches during installation...
If I loosen one shackle bushing (or spring eye) at a time, will the spring straighten out any, thus making it a pain to get the eye and bushing lined up with the shackle and bolt without compressing the spring (curving it a little more)?
This seems like it would be an easy job, but if I need to fight a sprung spring to get it back on it won't be any fun.
I plan on using a garage lift, so the truck's wiehgt will be off of the springs, but I may do it withthe wheels close to the floor so when I unbolt each shackle bushing the wheel won't pull the loosened spring too far downward.
Thanks for any help you can provide.
Old Jan 23, 2002 | 09:21 AM
AZ4x4f150's Avatar
AZ4x4f150
gamma
I found it easier to just remove the leaf springs and do both ends of the spring at same time since you're useing a garage lift it will be alot easier just have a jack holding up the axle. As for fighting a sprung spring you shouldn't be the only problem you might encounter is getting the stock bushings out they don't like to cooperate. make sure you putalot of white lithium grease in the new bushing where the mounting bolt goes and on the outside of the new bushing or else the squeaking will drive you crazy the only fighting you might have to do is getting the axle lined up on the center bolt of the spring and when you go to tighten up the u-bolts make sure you tighten them in a X pattern and check for u-bolt tightness a few miles down the road.
but other than that it is a fairly simple task to change the bushings out JUST DON'T FORGET THE LITHIUM GREASE urethane squeaks worse than a loose fan belt over every little bump, good luck
Old Jan 23, 2002 | 04:11 PM
Chuck P.'s Avatar
Chuck P.
If the old bushings give you to much trouble, fire-wrench 'em (careful of the fumes though-well vented area required). I think that's the worst part, gettin' the old out! Some also have a metal bushing in the spring eyes (in addition to the bolt bushing), not always easy to see after torching, usually this gets removed when switching to the poly, but do follow what the manufacture recommends.
Old Jan 24, 2002 | 06:30 AM
72f100's Avatar
72f100
