4x4 Van
Old Dec 7, 2008 | 08:53 PM
Boba Fett's Avatar
Boba Fett
4x4 Van
I got a 4x4 E-250 van from 1980. I need some sheetmetal parts for the body to get it back on the road. Anybody know any good parts sources. Need floor pan parts and rockerpanels.
Old Dec 7, 2008 | 11:21 PM
pfogle's Avatar
pfogle
The best thing to do is find a local junkyard that still has a few that are in good shape body wise. Get all the removable panels you need then buy one whole one for the other parts you need to cut out. It's a lot easier and cheaper in the long run.
Old Dec 8, 2008 | 06:00 PM
rebocardo's Avatar
rebocardo
JC Whitney for all Auto parts - Car, Truck, Jeep, Motorcycle & RV Parts
P.A.W.
Old Dec 8, 2008 | 08:38 PM
Boba Fett's Avatar
Boba Fett
Thanks for the info I'll check out JC Whitney.
Old Dec 12, 2008 | 05:18 PM
Fat Diesel's Avatar
Fat Diesel
Hey Boba, is your van a Quadravan? I have a 1980 Quadravan Ford 4x4. Just wondering...
Old Dec 14, 2008 | 08:23 PM
Boba Fett's Avatar
Boba Fett
yes it is.
Old Dec 14, 2008 | 08:24 PM
Boba Fett's Avatar
Boba Fett
Do you know where you can get body mounts for them? Do you use regular E-series mounts or do they use special ones for quadravan
Old Dec 15, 2008 | 10:29 AM
Fat Diesel's Avatar
Fat Diesel
Sorry. Don't know. Also just remembered mine's an 81. But try to get a hold of the guy at pathfinder-vans . If you search Pathfinder Quadravan on google it is the first one up. Good luck!
Old Dec 15, 2008 | 10:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Same mounts.
Quadravans were not made by Ford, so everything is the same as Econolines except the front end 4WD conversion.
The Econoline sheet metal is the same 1975/1991.
Old Dec 15, 2008 | 08:49 PM
Boba Fett's Avatar
Boba Fett
Thanks guys!
Old Oct 18, 2011 | 07:20 PM
bonetone's Avatar
bonetone
Hi Bill,Id like to ask a question of you please.I aquired a 79 Quad van ,Body is junk.Do you know what years the bodies are interchangeable,considering wheel base etc...Im in the high Desert and never find them local.Its normally an 1 1/2 to go out out and make all the measurments since the donor owners do not have a clue.Thanks you in advance.Im hoping to swap a camper conversion onto the chasis.
Old Oct 18, 2011 | 07:36 PM
Boba Fett's Avatar
Boba Fett
I think its 75 through 92 that are the same. I don't know if the later vans fit on the fram as well, but the bodies are different. Of course the interiors changed a bit from the seventies. I swapped an 88 on my frame.
Old Oct 18, 2011 | 07:52 PM
bonetone's Avatar
bonetone
Thank you was it fairly straight Forward?Are you happy with the results?Any pics posted yet
Old Oct 18, 2011 | 08:32 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Check LMCtrucks.com They have van body parts now!
Old Oct 19, 2011 | 08:59 PM
skillethead577's Avatar
skillethead577
4x4 truck frame
I dont know nothing about 4x4 vans but I have a 91 e 150 with a near perfect body and low milage 5.0 ,my question is ,can you just mount the body on to a f150 4x4 frame of the same year or would it be easer to just find the parts and mount them to the vans frame?
