reverse tilt hood-no limit
Old Dec 7, 2008 | 10:57 AM
paulkoppen's Avatar
paulkoppen
Hi there,can anybody help me out with construction on a reverse tilt hoodsystem on my 56 F100.I live in the Netherlands and I'm having big problems with the original hinges and would like to change to the "no-limit" reverse tilt hood design.Because of the costs(I am dutch) I would like to copy the "no-limit" system but I need a template for the strange formed guides that mount inside the hood and for the roller mounts that come in place of the old hinges.I also need the length of the two pieces of tubing that are welded to the pivot bar and that makes the hood pulled upwards and forward.
Is there anybody who can tell me wich system works better:the "no-limit"system or the "classicperformance"system,the one with the rollerguides on the inside of the fender?
I would appreciate it if anyone can help me on the way with some advice and the right measurements.
Thanks Paul.
Old Dec 7, 2008 | 02:32 PM
bnradams's Avatar
bnradams
Welcome to the forum paulkoppen.
I made my own reverse tilt from scratch, here is a link to my gallery that has some of the measurements I used.
https://www.ford-trucks.com/user_gal...&albumid=36110
Also check out this write up by Kent Boomer he has some great info that should help.
https://www.ford-trucks.com/article/...356_Fords.html
Old Dec 13, 2008 | 12:16 PM
paulkoppen's Avatar
paulkoppen
reverse tilthood
Thanks for the quick reply and you did a nice job on constructing your own reverse hoodsystem.Your information and the article of Kent Boomer helps me a lot.
Thanks!!!
54-F100
80
Oct 28, 2016 01:32 PM
EBEAR
26
Jul 15, 2016 09:24 PM
thepitshop
Jan 7, 2016 08:34 PM
Dr G
16
Sep 6, 2015 07:59 AM
