Sponsored by: Kumho
wheel size
Old Dec 6, 2008 | 10:17 PM
offroad17's Avatar
offroad17
wheel size
I am looking for some 15-16" wheels to go with some Dick Cepek Mud Country 33x12.50 tires. I think the bolt pattern for the 2004 F150 XLT 2wd is 6 on 135 but I am not sure. Is this right? Also, what are some good wheels for that size and tires? What width should be gotten for 12.50 tires? Thanks.
Old Dec 8, 2008 | 10:44 AM
78_4x4's Avatar
78_4x4
depends on what you are using them for. in the mud i like to run a thinner wheel, so when you air them down the bead doesnt pop off. but for looks, a wider tire looks cooler, and will give you a wider profile. with a thinner wheel they will be taller. hope this helps..
Old Dec 8, 2008 | 10:34 PM
aurgathor's Avatar
aurgathor
There's a big difference between 15" and 16". One will fit, the other won't.
Old Dec 10, 2008 | 06:41 PM
offroad17's Avatar
offroad17
Do they even make wheels for the newer F150s (6 on 135 bolt pattern) smaller than 17s?
Old Dec 11, 2008 | 12:38 PM
Opossum's Avatar
Opossum
I would refer to Dick cepek as to how wide a wheel to use but probably 9.75" or 10"
