Knocking bad!
Old Dec 6, 2008 | 09:15 PM
provohighboy's Avatar
provohighboy
Knocking bad!
my engine is knocking bad. it fires up just fine and has no other problems, but the knocking is pretty extreme. in an earlier post I mentioned that a mechanic thought that it might be a rod. Any ideas? Thanks guys.
Old Dec 6, 2008 | 09:32 PM
istfordinmylife's Avatar
istfordinmylife
Could be a lifter thats stuck or not getting oil.
Old Dec 6, 2008 | 09:39 PM
provohighboy
Rebuild
I've been trying to kinda get an idea, it's time for a rebuild anyways. I've never had to do that yet, but if i'm gonna get into it at all might as well try and get everything square!
Old Dec 6, 2008 | 10:45 PM
Freightrain's Avatar
Freightrain
Knocking or ticking? Lifters "tick", but rods "knock".
Using a broom handle(or even a long 3/8" extension), put it to your ear and then touch the block down low and up around intake. You'll quickly discover what the problem is.
85e150's Avatar
85e150
Time for a rebuild + a knock? Best get to it so you don't ruin your crank or window the block with a rod. If you haven't ruined the crank already.
Are you going to rebuild yourself or buy a short block?
Old Dec 6, 2008 | 10:52 PM
provohighboy
Rebuild
I'm gonna have a machine shop rebuild it. and yeah it is definitley a knock! hopefully it's rebuildable.
Old Dec 6, 2008 | 11:36 PM
85e150's Avatar
85e150
Since it's an FE, be sure to read the forums here before you have someone rebuild it.
Stock Ford truck engines have timid cams and low compression. Fine with 25 cent gas and farm driving.
A slightly different cam, and compression in 9.5 zone, along with a properly tuned carb & headers can net you twice the stock HP and the same MPG, if not better mpg.
It doesn't cost much more to rebuild this way--all that stuff is going to be replaced anyway (internals I mean) so having different parts installed shouldn't raise the cost dramatically.
Serving suggestion, your mileage may vary.
Good luck with it.
Old Dec 6, 2008 | 11:41 PM
provohighboy
Monday
I'm supposed to talk to the machine shop on Monday. I hear that they are a pretty repuitable company. Do you know of any forums off hand that have a rebuild project parts list that would help me get the most bang for my buck?
Old Dec 7, 2008 | 10:27 PM
masterbeavis's Avatar
masterbeavis
Fordfe.com, try there. Lots of good tech there. Search with Retsin, two mints in one. :2thumbs:
Old Dec 8, 2008 | 11:54 AM
85e150's Avatar
85e150
Some of the posts here have parts listed. If you see one that seems to fit what you need, you can always PM the fellow and get more info.
Old Dec 8, 2008 | 01:30 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Just post here in the FE forum about what you want your engine to do (truck or car) and what you need it to accomplish - daily driver, towing, all-out-muddin', you get the idea.
The guys here will be more than happy to spend your money
