Turbo installation Problem....HELP!!!
Old Dec 6, 2008 | 09:57 AM
dakotajeep's Avatar
dakotajeep
Ok, I am installing a Banks turbo. The issue that I am having is when I removed the brass plug from above the oil filter (to feed oil to the turbo) I have coolant streaming out. I put the plug back in but I leaked about a cup of coolant on the ground in the mean time.
My question is whether or not there should be coolant there or not? Since it says in the installation instructions to remove the plug and place lines to pump oil to the turbo I would obviously assume that coolant shouldnt be there. Do I have a cavitation problem? If anyone needs pics of the exact location then I can take some......
Thanks
Thad
Old Dec 6, 2008 | 10:03 AM
Franklin2's Avatar
Franklin2
Sounds like the wrong plug. If you have water in the oil, it would all be in the bottom of the oil pan. If it's mixed in the oil, it makes the oil look white and milky.
Old Dec 6, 2008 | 10:14 AM
dakotajeep's Avatar
dakotajeep
Ok, now I wonder where the right plug is. Thats crazy since it is EXACTLY where they described it.......I REALLY hope that you are right and that I am very wrong....
Thanks
Thad
Old Dec 6, 2008 | 11:38 AM
dakotajeep's Avatar
dakotajeep
You were correct. I found it and got in taken care of.....
Old Dec 6, 2008 | 04:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Hex head plugs = coolant
Square head plugs = oil
Old Dec 6, 2008 | 07:06 PM
dakotajeep's Avatar
dakotajeep
Thanks Dave
