head stud
Old Dec 9, 2008 | 07:04 PM
JReinert's Avatar
JReinert
Arp's All The Way.
Old Dec 14, 2008 | 11:40 PM
turbo60's Avatar
turbo60
I pulled my motor out to install the studs. I have a lot of wires etc running into my cab and didn't want to cut and reconnect all my accessory wires if I had to pull the cab off. Pulling the motor out was not that bad. If I had to do it again I can probably get the motor out under 5hrs easy. I would not advise trying to do a head job with the motor in the truck or not pulling the cab off. You have to torque the studs to 245lbs and requires a lot of leverage and space to get a torque wrench in there with a long enough handle. I recommend that you get your heads resurfaced and magnafluxed. Both my heads were cracked. I bought 3 different sets of used heads, all 3 sets were cracked. I installed a EGR delete kit in it as well, runs great now and lower EGT's. This is the way to do it right.
06FUN
Oct 29, 2016 07:53 AM
fenix1
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 26, 2013 01:32 PM
fenix1
Bronco II
May 26, 2013 01:30 PM
YoungFordAddict66
40
Jan 20, 2011 12:24 AM
Jeff Fisher
Apr 25, 2006 10:23 AM
