Long Tube Headers
Old Dec 5, 2008 | 12:01 PM
Redneck1465's Avatar
Redneck1465
Long Tube Headers
Has anyone found a set of long tube headers for our style trucks? I want to put the GT-40P heads on my 351W so if you have any ideas let me know. Thanks.
Old Dec 5, 2008 | 12:23 PM
bashby's Avatar
bashby
https://www.ford-trucks.com/forums/7...k-headers.html
Old Dec 6, 2008 | 07:23 AM
Opossum's Avatar
Opossum
If ya tell me more about your truck I bet I can get ya some part #'s and some good recommendations. And yes many companies make headers for your truck.
Old Dec 8, 2008 | 10:50 AM
Redneck1465
F150 4x2 with a 351W extended cab 8ft bed.
Old Dec 8, 2008 | 04:54 PM
Opossum's Avatar
Opossum
There's plenty of headers available for your truck. I have sold and installed lots of headers and I am a fan of the Hedman product. You can save a few bucks (maybe $20)going with a cheaper brand but the quality is worth it, and they use a ball and socket flange which removes the need to a collector gasket that can fail and makes fitting the new exaust much easier.
You have 2 good choices from Hedman; Hedman Hedders, Headers - summitracing.com
There less expensive line, the tubes are 18 gauge, flanges 1/4 inch, and they just have regular paint on them to keep them from rusting in the box.
Or I recommend you spend a few extra bucks and get the elite series. The tubes are 14 gauge much thicker to they sound better, last longer and are much stronger. They got 3/8" flages so they warp much less, and come with a cermic coating, this coating will all but make rust imposable, will stand up to the heat, and is a thermal barier holding heat in the header.
Also gaskets are very important don't even bother with regular gaskets or most header gaskets. Check these out from Remflex REMFLEX Exhaust Gaskets: Home Page these are they best header gaskets I have ever seen and all I use, I have never had a set fail, the company is small, friendly and vary helpfull, and everthing is made in the USA.
Header bolts are vary important on a Ford windsor motor, there is alot of good stuff on the market take a look around. I like and use ARP stuff and would use a stud kit for your setup, stainless if ya go with the elites. Like these http://store.summitracing.com/egnsea...4294922550+115 there's much less expensive options though.
