trans change?
Old Dec 6, 2008 | 07:40 PM
willeo6709's Avatar
willeo6709
it will be basically the same sweet spot without the trailer... drive it 62 and you will likely get 17-20 mpg depending on mix of stop/go to open road...assuming the winter fuel does not affect you as much as it does in Iowa. My 02 excursion does its best at 1750 rpm...right at 62 on the speedo, 265's and 3.73's
