Sponsored by: Auxito
power locks and cruise control
Old May 7, 2000 | 09:50 AM
kevin glenn's Avatar
kevin glenn
My power locks on my f-150 will lock my doors, but no longer will unlock. Also my cruise conrtol works but the display light on the dash no longer comes on when in use.
Old May 7, 2000 | 04:42 PM
nitro94's Avatar
nitro94
Door lock problem sounds like a bad switch. Fuse or open in wiring would cause it not to work at all. Can be checked with a test light if you can read a wiring diagram. Check the bulb in dash for cruise problem.
Old May 7, 2000 | 05:41 PM
cpkoch's Avatar
cpkoch
