Cam Selection???
Old Dec 4, 2008 | 07:05 PM
7mpg302's Avatar
7mpg302
Cam Selection???
I am building a 78 460 for my 1978 f150 4x4. i am going to use the truck as a daily driver when i finish it. but it is also going to be a weekend wheeler. mostly mud and water, but the occasional rock or two. So i will NOT need a lot of the low end torque used in rock crawling?
I am looking for a cam that would give me a lot of lope and sound BA. I want your opinion too. i want to know if you think im crazy. do you think that i should go with a cam that has lope and not low end torque, even if it i use it as a weekend wheeler? you think that i will get stuck more if i do?
I just love the sound of cam lope!!!!!!!!! i mean, who doesn't ... I was looking at the comp cam 34-231-4 and 34-235-4. these are both pretty stock cams. 34-235-4 has some lope, without giving up low end torque. that is a pretty good comprimise....but i want LOPE lope. Do you know any cams that would do this for me? once again, let me know if im crazy for giving up a vital part of offroad rigs (torque) for how it sounds!!!!!!!!!!!!! LET ME KNOW!!! Thanks and sorry for the ongoing, rediculously long post!!!!
Derek
Old Dec 5, 2008 | 01:42 AM
petes79f150's Avatar
petes79f150
Not trying to be a smart-azz, but do you know what characteristics make a certain cam have a 'lope'? Timing Tutorial
Typically, lopey cams and low-rpm performance (off-roading) are mutually exclusive. I don't do a lot of 4x4 stuff, so I couldn't give you a specific pick. Too bad Comp doesn't make the Thumper cams for the 460.
I'm running a custom ground cam by Harold Brookshire in my '69 Mach1 390 that has a pretty aggressive lope, but still does OK around town. Harold invented the Voodoo line for Isky, designed most of the old standards for Comp, among others, but he's fixin' to retire, and is doing his own thing again, but probably not for long. He might be able to help you. brookshire@panola.com <brookshire@panola.com>
Another is Mike Jones- very good people...HOME
The best thing to do is either fill out a cam recommendation form http://www.compcams.com/technical/ or call and talk to someone at Comp. They do custom grinds all the time. Got one in my '79F150.
Pete
Old Dec 5, 2008 | 06:10 PM
JBradley500's Avatar
JBradley500
i think 34-231-4 will be better than the other choice. anything with over 220 at .050 is going to be hard to run vacuum secondaries. you could get something custom ground with your application and telling them you want to hear it thump a little and maybe they will put it on a 108 lsa or something to give you more sound without adding too much duration.
Old Dec 8, 2008 | 10:57 AM
78_4x4's Avatar
78_4x4
good info............
