Ranger keeps dying?
Old Dec 4, 2008 | 01:51 AM
rhino_160's Avatar
rhino_160
Ranger keeps dying?
89' Ranger 2.3 L 5 speed.
Hey all, my Ranger keeps acting up on me and i need some help please.
It runs fine when idling and while driving. the only time it dies is when i have been driving for a period of time and push the clutch in to turn on a road or come to a stop. it acts like it is going to idle down to the normal 700 or so rpm range, but then drops off and dies. it does not do it every time, but if i have drove continuous for say more than a mile, then apply the clutch, it dies. if i can tap the gas at this moment, it is fine, but if not it will die. it starts right back up and will idle fine. i am confused
i replaced the fuel filter, but no help. i bought some new plugs and wires but have not replaced yet. you think the plugs will fix this or what? thanks
Old Dec 4, 2008 | 03:18 AM
Pablo-UA's Avatar
Pablo-UA
try to bed off, pull out fuel sender and inspect fuel pump. it is old good '89 ranger. I have '89 aerostar and changed fuel pump twice last 5 years...
Old Dec 4, 2008 | 05:51 AM
Lead Head's Avatar
Lead Head
I'm guessing an 89 Woul dbe fuel injector? It might be your air idle valve
Old Dec 4, 2008 | 07:19 AM
Pablo-UA's Avatar
Pablo-UA
my be. Ok, before doing something it would be a good idea to pull codes, check fuel pressure, inspect IAC.... Is it EEC-iV controlled truck? There were early rangers with CFI ore with carbutrator. Snapshot of engine compartment may help
Old Dec 4, 2008 | 08:17 AM
matt's2.9STX's Avatar
matt's2.9STX
Golll-eee Pablo, '89 isn't THAT old! Yeah, 89 is EEC-IV.
Ford Ranger/Bronco II EEC-IV Testing
To get the codes without fuss. In bad weather, just use the jumper method. Much easier to transcribe the blinks from driver's seat. Easier to see which pauses are which too esp for 2-digit codes vs 3 digit codes.
Also has MFI injectors so throttle body simply meters air.
Old Dec 4, 2008 | 08:43 AM
Pablo-UA's Avatar
Pablo-UA
'89 had MAP, not MAF. so I sugest it is not vac. leak. I suggest dirty IAC ore low fuel pressure.
Old Dec 4, 2008 | 05:14 PM
waynebo's Avatar
waynebo
Throttle body may need to be cleaned,i've had more than one do that and cleaned the throttle body and it fixed it.
Old Dec 4, 2008 | 07:23 PM
wendell borror's Avatar
wendell borror
Also could be the plugs, when's the last time it's been tuned up? My pinto's use to be bad for that when they needed plugs. You didn't get the mileage out of a set of plugs back then like you do today.
