Code Question
Old Dec 3, 2008 | 10:10 PM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Code Question
Pulled a couple codes this evening. Had the normal KAM and injector pressure high/low. Had never seen this code pop up before--PO733 Gear 3 Ratio Error. What is this one? Not too worried, been driving/shifting like normal. Thinking also about making a call to BTS to see if Brian may know what it is.
Old Dec 3, 2008 | 11:08 PM
Pocket's Avatar
Pocket
If it's shifting ok, I probably wouldn't worry about it. With aftermarket tuning, and an aftermarket transmission, you're bound to get weird codes that pop up randomly.
Old Dec 4, 2008 | 09:43 AM
ggirten's Avatar
ggirten
This is from another site with similar issues:
Incorrect gear ratios can be caused by, wrong tach info, bad input turbin sensor" top of trans left side," or trans slipping. Before condeming the trans, the codes should be cleared and vehicle driven again while watching these inputs on a scanner. If they ck out ok, then you can assume the trans is slipping. Not good news.
Old Dec 4, 2008 | 10:57 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Codes have been cleared since last night, today we shall see if it throws the code again.
NeXtras
Apr 1, 2007 07:05 PM
M998
Mar 18, 2005 09:16 PM
bcj6402
Aug 29, 2002 01:09 PM
Brian460
Aug 13, 2002 09:23 PM
Brian460
Aug 13, 2002 12:08 PM
