Have a 92 Ranger Reg cab (2WD), right now I have 215/70/14's on. I want to put 31/10.5/15's on it with 15x8's.
To do this I know I need a lift. Would a 2" Daystar Leveling Kit for the front and 2" Rough Country blocks for the back work? This is just for looks, the truck just does daily driving.
If it isn't enough would I be able to fit 30/9.5/15's on it then with that lift?
Okay...probably a stupid question, but I'm new to this (please don't laugh), can I stack two coil spacers? I can get 3" or 4" rear blocks no problem. I need a cheap way to do this. The cheapest 4" suspension lift for my 2WD I can find is like $430. The spacers and blocks will only be $150, or $250 if I can stack...
[updated:LAST EDITED ON 01-Mar-02 AT 12:10 PM (EST)]no you cannot stack the spacers what you can do to get alittle more lift and it actually works better with the spacers is go to a junkyard and get the spring cups off a 2 wd f150 they stand just under 1" tall and will give you aprox 3" with the spacers
or you can get a set of leveling springs for aprox $170.00
as for the 31 they should fit with the spacers and the f150 spring cups
