Help Electrical Problem Newby
Old Dec 3, 2008 | 11:28 AM
tboss619's Avatar
tboss619
hI GUYS Im a newby here so bear with me for a while I have a 1994 E-350 van chassie with a coachman santara 29ft class c motorhome on it I am having a problem with my lites I have turn signals on the rear but not on the front and I have emerg. flashers on the front but not on the rear. With the emerg. flashers on I can flip the stick for turn signals on and have turn sig. on the front and rear and I have no stop lites the running lites are fine and the brake switch on the brake pedal is working fine with 12v power in and out Is there a stop lite relay some where I might be missing ? Does the brake lites work thru the multifunction switch. Im thinking it might be the multifunction switch for the turn signals and flashers but dont know abt the stop lites . It has been suggested maby a bad ground but all the lites are burning strong with no cross talk between them. Is there a way I can test the multifunction switch for problem other than probing with a test lite. Does anyone have a suggestion here for a newby? tks Terry
