Powerstroke Exhaust
Old Dec 2, 2008 | 10:06 PM
imboostedru's Avatar
imboostedru
Powerstroke Exhaust
I was wondering if a 94 Powerstroke exhause would fit on a 94 IDI truck? Since they are about the same truck the exhaust routing should match up. I've tried searching and kept getting different results. Anyone run or know of someone running this set-up? Oh yeah, I know the downpipes will be different.
Shawn
Old Dec 2, 2008 | 10:52 PM
starmilt's Avatar
starmilt
I doubt they will be a bolt up you could probably modify one but you would still have govternment restricted exhaust.
Old Dec 2, 2008 | 10:55 PM
imboostedru
Yeah, I would be getting a ATS Housing and downpipe.
Old Dec 2, 2008 | 11:12 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The stock 94 Power Stroke used the same smashed downpipe that Ford put on the 94 IDI.
So unless you get an aftermarket exhaust, you will not see any gain.
The stock downpipe was smashed until the 99 came out.
Old Dec 2, 2008 | 11:34 PM
S.P.'s Avatar
S.P.
imboostedru (yes I am) ...
Yes I am told that the '94 thru. '97 ps ehxaust will fit with slight mods..but only down pipe back...
Old Dec 3, 2008 | 09:53 PM
goodB0Y's Avatar
goodB0Y
I've been looking into this my self and from looking just at pictures off of the net the two system's side by side they look very similar... down pipe back for the p/s and y-pipe back for the idi... the only difference I can see is a bend in one of the intermediate pipes on the p/s... check out the links and you can see the two systems I'm talking about.... looks like some minor pipe work to make it work
Dynomax Performance 19430 - Ultra-Flo Welded Exhaust Systems - summitracing.com
MagnaFlow 15939 - MagnaFlow XL Performance Exhaust Systems - summitracing.com
Old Dec 4, 2008 | 06:19 AM
Dodge/Cummins's Avatar
Dodge/Cummins
I've compared my '94 IDI turbo to my '97 PS and it looks like it would ALMOST be a bolt on from the down pipe back. However BOTH of my trucks have been "straight-piped" by the POs so I'm not sure.
I'm assuming you want an aftermarket system and that's why you're asking?
Old Dec 4, 2008 | 12:53 PM
ghunt's Avatar
ghunt
For what it's worth, on my truck from the downpipe back to the tailpipe (or stacks or whatever) I have no bends whatsoever.
For my original exhaust, behind the downpipe I had a 3"-4" reducer, a long straight section of 4" pipe, the Walker 4" tailpipe, and a tip.
I had about $150 total in that, with clamps hangers and all...add $50-100 if you want a muffler.
Old Dec 4, 2008 | 01:57 PM
imboostedru
I can see how it would work. The only thing is I have a camper so I can really have it doming out the back. How is the clearance between the axle and exhaust?
Shawn
Old Dec 4, 2008 | 03:57 PM
ghunt's Avatar
ghunt
Doming?
Clearance was good on my truck. The tailpipe is specifically made for these trucks, it's the same one that comes in the n/a 7.3 IDI exhaust kit.
Old Dec 4, 2008 | 04:57 PM
Dodge/Cummins
I think he meant coming, typo.
Old Dec 4, 2008 | 06:54 PM
imboostedru
Yeah, I don't have ispell at work so I missed it. I also didn't see about the tailpipe, I just skipped that part and read straight.
Shawn
