8.8 agressive trac lock
Old Dec 2, 2008 | 08:45 PM
76 F-150 390FE's Avatar
76 F-150 390FE
im getting ready to rebuild the trac lock in the ranger here soon because im sick of haveing posi one time then one tire fire the next. i have a yukon posi in my 86 and that thing chirps tires idleing around corners is there any clutch kit out there or some modification that can be done to make this thing do what its supposed to do and spin both tires ALL the time i know about putting the 31 spline s spring in it but can you add an extra firction disc or something like that?
Old Dec 2, 2008 | 10:54 PM
85e150's Avatar
85e150
Google 'ford trac lock' and find:
Rebuilding Your Traction Lock Differential
What to expect, sort of:
Traction Lock Rebuild Problems! - Ford Mustang Forums
You get the picture there. If you don't want to fool with the Trac lock, consider a different limited slip or locker:
Currie Enterprises Racing Rear End Categories
Get a Detroit Locker and DIY:
https://www.ford-trucks.com/article/...it_Locker.html
