Project 86/ Spring Tire Question
Old Dec 2, 2008 | 04:39 PM
Ztitan's Avatar
Ztitan
Will the stock front springs on an 86 150 allow enough room for 31in tires without rubbing?
If not how high does it need to go? Not really looking to lift it much if I can get away with it.
Also I am going to flat bed this thing. But I am in search of some light weight options. Any suggestions? Every Flat bed I have ever built has been over engineered and way to damn heavy.
Old Dec 2, 2008 | 06:56 PM
pfogle's Avatar
pfogle
The should. The stock 235/75/15 are 29 inches. Two inches should not rub. It also depends on how wide you're going.
Old Dec 2, 2008 | 07:48 PM
Ztitan's Avatar
Ztitan
31 10.50 is the tire size.
Old Dec 2, 2008 | 07:52 PM
zpmps2's Avatar
zpmps2
Hey, is the truck 4x4 or 4x2? This will help us all out. Plus the future people that search about this topic.
Old Dec 3, 2008 | 12:42 AM
Ztitan's Avatar
Ztitan
4x4
I wouldn't own a 4x2 let alone mention lifting it for a bigger tire. But that's just me. I can see how the correct info would be helpful though.
Old Dec 3, 2008 | 08:12 AM
pfogle's Avatar
pfogle
With a 10.5 you MIGHT rub a little bit. The rears will be fine, it will be the fronts when you go around a corner.
Old Dec 3, 2008 | 11:24 AM
Ztitan's Avatar
Ztitan
I guess I could through in a 2 in lift kit.
Old Dec 3, 2008 | 11:53 AM
pfogle's Avatar
pfogle
I think I'd try them. Depending on manufacturer they may or may not rub.
Old Dec 3, 2008 | 12:01 PM
Ztitan's Avatar
Ztitan
Alright I guess I can go get them mounted and give it a go.
If need be what about something like those 1-2 inch bushing type spacers that go under the spring? Will that toss the alignment out bad?
Old Dec 3, 2008 | 04:42 PM
pfogle's Avatar
pfogle
Stay away from spacers. They're more trouble than they're worth. They will likely kick the alignment out so bad it won't be drivable and the shop won't be able to get it close enough to be.
Old Dec 3, 2008 | 05:16 PM
Ztitan's Avatar
Ztitan
Glad you said that.
I got one tire on the front. Cleared fine. However the other side is going to require a spring replacement.
Sags a bit.
I called a junk yard and he said sure I got a set, 100 bucks. I laughed so hard while I told em they were 79.99 at Autozone New for a set.
He did not believe me but at any rate I have a set ordered.
Old Dec 3, 2008 | 07:34 PM
Franklin2's Avatar
Franklin2
I ran 31X10.50's on my 80 4x4 f150. With the stock wheels, they would rub the radius arm when I turned sharp in the parking lot. Not a big deal, you could hear it and feel it rubbing on the cleats through the steering wheel.
I then got a set of cheap chrome modular wheels 8 inches wide, and mounted the same tires on them. The were offset more and pushed the tire out farther from the truck, and they did not rub the radius arms.
Old Dec 4, 2008 | 11:10 AM
pud's Avatar
pud
I had an '80 bronco with 33x12.5's on wagon wheels...only rubbing was on the radius arm at full lock
Old Dec 4, 2008 | 12:19 PM
Sycostang67's Avatar
Sycostang67
I had an 80 bronco with 35/12.50's and no lift. The tires rubbed the radius arm and the tops of the fenders every time it hit a bump. A guy I used to work with had an 86 F-150 4x4 and ran 32/10.5 on 15x8's with minimal rubbing.
Old Dec 4, 2008 | 04:28 PM
Jeffery the first's Avatar
Jeffery the first
the broncos i and my buddys had would only fit 33/12.5s under them then one of my friends lifted his 6inches and put 38 i wanna and about 2weeks later it rolled down a hill lol while it was parked we went back to get a truck to pull him out came back and the bronc was on the bottom of the hill
