engine runs rough
Old Dec 1, 2008 | 07:41 PM
flynntyme's Avatar
flynntyme
engine runs rough
have a 1987 ford 250, starts up and idles fine, if i ride it slow and easy runs fine, but if i want to accelerate and or go faster, the engine runs "rough". it like it stuttering almost! didnt know if there were any suggestions! thanks for your time................wflynn2@student.fsc.edu
Old Dec 1, 2008 | 07:55 PM
goodB0Y's Avatar
goodB0Y
sounds like it's either starving for fuel or a missfire... a pluged fuel filters or bad fuel pumps can cause what you describe(fuel starvation) as well as a bad plug, wire, or cap and rotor(miss fire).... its hard to describe the diference between the two... I'd know right away if I drove it...lol. is your truck fuel injected... can't remember when they changed over
Old Dec 1, 2008 | 08:24 PM
Opossum's Avatar
Opossum
Which engine do you have in 87 the 460 was carbed and all else injected?
Old Dec 1, 2008 | 09:43 PM
lv2race's Avatar
lv2race
Check for codes too. If you don't have a code reader, check the link..........
Ford Fuel Injection How To Run a Self-Test
Old Dec 1, 2008 | 10:01 PM
flynntyme's Avatar
flynntyme
its a 5.8, last year of the carburetor, dont think its the 460, either the 351 or the 302
Old Dec 1, 2008 | 10:14 PM
Opossum's Avatar
Opossum
So it's carbed? Then it has the holley carb?
The first thing to do is check the ignition, Had a tune up lately?
Old Dec 1, 2008 | 10:22 PM
goodB0Y's Avatar
goodB0Y
can you give us some more info like does it actup more going up a hill? does it feel like its running out of gas?
Old Dec 1, 2008 | 10:26 PM
goodB0Y's Avatar
goodB0Y
most of the time when people have complaints like yours it's an ignition problem... a fuel problem like a bad fuel pump or filter will more often feel like your running outa gas. Ignition problems give you a studering symptom or shaking...
