I hate my ESOF
Old Dec 1, 2008 | 06:34 PM
60RatRod's Avatar
60RatRod
I hate my ESOF
So i figured out why my ESOF did'nt work. The plug to the solenoid was loose. I plugged it in tight and the vacuum pump started running non stop even with the 4x4 switched off, additonally I lost My AC, Im just plain frustrated. I fixed all my vacuum leaks found my bad electrical connection anfd yet still problems. Oh yeah it ran my batteries dead overnight. What the heck is up. I grabbed some relays I uess Ill try them next.
Old Dec 1, 2008 | 07:25 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I hate mine too.
Biggest POS that Ford has ever unleashed on us.
Old Dec 1, 2008 | 09:37 PM
HKusp's Avatar
HKusp
Glad I have the manual shift lever, except for that time that I cheese grated the skin off the back of my hand with it jamming between the handle and the back of the salt spreader controller...
Old Dec 1, 2008 | 09:42 PM
jdecker88's Avatar
jdecker88
Thats why I went to warn manual hubs.
Old Dec 1, 2008 | 09:53 PM
preppypyro's Avatar
preppypyro
I sure like the convenience, but sure hate when it doesnt work!
I wish my 03 had the handle too instead of the switch on the dash.
Old Dec 1, 2008 | 09:55 PM
HKusp's Avatar
HKusp
I like knowing it's going to work. The coversion is a hard one too, because they are two totally different transfer cases I hear.
Old Dec 1, 2008 | 09:58 PM
clux's Avatar
clux
I love my ESOF.
I still haven't experienced any problems with it at 248,000 miles, but I use it almost every day and I assume that's what keeps it working.
Old Dec 1, 2008 | 10:07 PM
preppypyro's Avatar
preppypyro
Yeah clux that definatly would hurt!
Mine screwed up once, and I fixed it by spraying wd 40 everywhere haha.
So far mine hasnt broke down on me, besides a few glitches now and again.
When i was under my truck today, i seen there is a hole in the body that can be punched out, and im pretty sure its for a 4x4 stick.
Old Dec 1, 2008 | 10:15 PM
twags6's Avatar
twags6
The vacuum pump kept running with the key off? It should only run with the key on. There's still a leak somewhere if its only blowing air out of the defrost vents.
Old Dec 2, 2008 | 09:16 AM
superduty4x4's Avatar
superduty4x4
I like my ESOF so far, but it hasn't given me a reason not too yet. I think that using it frequently is the key like clux said.
Old Dec 2, 2008 | 09:49 AM
bdrummonds's Avatar
bdrummonds
Trevor is correct. If the pump keeps running then there is a leak somewhere.
after you get the leak fixed, consider going to Warn Premium hubs ($300) they are old school get out and lock the hubs when you want 4x4, but you will still have to turn the ESOF switch to engage the xfer case.
Old Dec 7, 2008 | 04:59 PM
60RatRod's Avatar
60RatRod
With a lot of folks help reading posts and guzzles page, I've determined my Auto Hubs are toast, I've wrote down an etensive list of ford P/N's and will start calling around pricing seals/O-rings, bearings/studs, etc. Monday. But with the extensive list of parts and the amount of rust I am wondering if it would'nt be just as cheap to buy Warns. Here's what i'm wondering, would the Warns include new or replacement needle bearings? Also is there a link or thread on Warn hubs install with good pics and step by step.
Old Dec 7, 2008 | 06:22 PM
cps's Avatar
cps
Just go to Warns web site and you will find all the info you need including directions on install and an exploded view of their hubs. It takes about 10 min a side to install.
