Maryland Chapter Join Chapter, Leader:
DECEMBER MD B/S Thread
Old Dec 7, 2008 | 08:54 PM
  #181
flathead95hp's Avatar
flathead95hp
How's it going Dave?
Old Dec 7, 2008 | 08:57 PM
  #182
80351's Avatar
80351
Originally Posted by flathead95hp
I Don't remember. LOL
How, are ya
Old Dec 7, 2008 | 08:58 PM
  #183
flathead95hp
Not too bad, Just wishing it was spring again.
Old Dec 7, 2008 | 09:01 PM
  #184
80351's Avatar
80351
Know what you mean even with the
heater in the garage it cold as a
........you know.
Did I send you my new phone #?
Got the truck done except for 1
vacuum line off
Old Dec 7, 2008 | 09:04 PM
  #185
flathead95hp
........you know.
vacuum line off
you did send me your new number and it's already programmed into my phone.
what was the problem with the truck? V/C gasket?
Old Dec 7, 2008 | 09:07 PM
  #186
80351's Avatar
80351
yep,
when we put it on, the lower rear bolt pushed the the gasket inside
so it was wide open for about 2 inches.
And I have 1 vacuum line not hooked up so I need to find where it goes
Need to talk to you about something too
Old Dec 7, 2008 | 09:08 PM
  #187
flathead95hp
yep,
when we put it on the lower rear bolt pushed the the gasket inside
That explains the smoke machine effect. Is it running better now?
Old Dec 7, 2008 | 09:12 PM
  #188
80351's Avatar
80351
Only started it for a few minutes,
everything is covered with oil so
I didn't want it running in the garage.
Do you have a decent vacuum diagram book?
Old Dec 7, 2008 | 09:14 PM
  #189
flathead95hp
I have alldata at work, I can get the vacuum diagrams for you tomorrow am if you want.
Old Dec 7, 2008 | 09:16 PM
  #190
80351's Avatar
80351
I know if I look at another truck I'll
see where it goes right away.
Its on the right side. One side goes
down around the back of the engine
there is a break which is where the
line is undone that goes to the engine
somewhere and on the other side of the break
goes to a hareness that goes inside so I'm thinking
it is a feedline for the heat vents.
  #191
flathead95hp
want to shoot me a pm about what you want to talk about.
Old Dec 7, 2008 | 09:18 PM
  #192
80351's Avatar
80351
Cool, but I don't get off til 5:30 now can you leave them somewhere
at the shop and I'll pick them up?
sending PM
Old Dec 7, 2008 | 09:19 PM
  #193
flathead95hp
sending PM
Sure, no problem, there is a black mailbox next to the door that I can put the paper work in.
Old Dec 7, 2008 | 09:26 PM
  #194
80351's Avatar
80351
OK thanks paul PM sent.
Gootta go nite nite.
Old Dec 7, 2008 | 09:29 PM
  #195
flathead95hp
Ok, catch you tomorrow. Have a good nite Dave.
