New Hampshires December Chat Thread
#94
Hi Dave, Shaun and Sean..
Dave I checked out the tranny pan install and it looked good..
Not much of a clearance issue if you ask me..
I tell you those undercarriage pics were good..
It looks mighty clean down there... Not a spec of grease or oil that I could see..
#99
Doing good. Thought the new belt would solve an issue with the charging system but looks like time for another alternator.
#101
Yeah it does. The dealer replaced earlier this year but I think when the old battery started going south for the winter it messed something up in the alternator.
#103
I have to check it Sean. But The lights are flickering bright to dim at night. I can rule out the battery, the belt and all the connections so that leaves the alternator.
#104
Don:
The van is only in the low 20k miles so little seepage to date.
The day before I took the photos it had rained, so I had about 55 miles at 55mph of pressure washing the under carriage.
#105
Could be voltage regulator... Is it seperate on your truck or internal to the alternator?? I am not sure..
The voltage regulator's job is to keep a constant voltage level..
