power steering pump
Old Dec 1, 2008 | 06:36 AM
stsscott's Avatar
stsscott
power steering pump
Hi All:
Anybody know how to get the pump off the bracket on a 92 f150, there is a set screw in the center of the pulley with a collar over it, does the collar unscrew? (righ or left handed?)
thanks
Scott
Old Dec 1, 2008 | 07:54 AM
MustangMatt96GT's Avatar
MustangMatt96GT
you need a powersteering Lully pullar... you can rent them at the parts store. But let me warn you, they are a pain in the *** to use.
Old Dec 1, 2008 | 08:01 AM
stsscott's Avatar
stsscott
but how about the center screw???
Old Dec 1, 2008 | 09:12 AM
Conanski's Avatar
Conanski
The center screw isn't a screw.. who knows why the decided to make it look like a screw because it's just part of the pulley. As stated you need a power steering pulley puller and a good pneumatic impact wrench, you'll never get it off with a ratchet because you won't be able to keep the pulley from rotating.
Old Dec 1, 2008 | 09:14 AM
Opossum's Avatar
Opossum
There is no center screw that is the shaft, the pulley is just pressed on and needs to be pulled off. The collar that you see is for the tool to grab onto. The tool clamps onto that collar and then you turn in a bolt that pushes on the shaft pulling the pulley off. It cannot be done without the puller and once you see the puller it will all make sence.
Funny simultanious posts that say the same thing.
Old Dec 1, 2008 | 04:45 PM
EPNCSU2006's Avatar
EPNCSU2006
I'm not sure what I did, but I got it off without any problems using just a ratchet. There must have been another hex to hold with an open wrench or something that I can't remember because there's no way I held the pulley by hand.
Old Dec 1, 2008 | 05:06 PM
Opossum's Avatar
Opossum
Good pullers have a big hex that you can put a wrench on while you ratchet in the bolt.
