Modular V10 (6.8l)
Rear End
Old Nov 30, 2008 | 10:09 PM
Pete Magnus's Avatar
Pete Magnus
Question Rear End
Hi guys , I want to know were do you look to find what type of rear end gearing that you have? I have a 1999 F350 4x4 cc longbed with a V10 and plan on putting Kumho 37x13 tires on it. My truck gets off the line pretty good but I just want to know before I go and put bigger tires on. Thanks guys.
Old Nov 30, 2008 | 10:25 PM
Monsta's Avatar
Monsta
Sit. Stay.
What is the 2 digit code lsited under AXLE on the door jamb label?
There is a code decipherererrrrerrrerrrrerererr (too many "er"s) up top in the Super Duty forum. It's in the FAQ.
FWIW, you have two choices 3.73 or 4.30. Plus, either can be open or limited slip.
In fact... (on edit) here's the codes.
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
Old Nov 30, 2008 | 10:42 PM
Pete Magnus
Cool, I checked and it had D3 under axle = 4.30. Will this gearing be up to the task of 37x13 r20 tires?
Old Dec 1, 2008 | 12:42 PM
V10_Cougar's Avatar
V10_Cougar
Hey Pete,
I'm currently running this set-up. LSD 4.30 37x14.50x16.5 (Super Swamper Tires) It also has a 6 inch lift. I get about 9-10 mpg, at 65mph my tachometer reads 2050. I take it easy on the go-pedal for more mpg if you know what i mean. To answer your question, yes it will be up to task. However, a lot of owners prefer the 4.56. I should have gotten the 4.56 but the 4.30's seem to pull fine for my needs. BTW, are you planning a lift for those 37" tires. I have ran 35" in tires stock form with minor rubbing on the fender walls.
Old Dec 1, 2008 | 05:35 PM
Pete Magnus
Yes V10 Cougar, I plan on getting a 6.5 Pro Comp lift with 37x14-50 r20 in January. I myself drive like an old lady at times for better mpg. Do you have any rubbing with those tires with a 6 inch lift?
Old Dec 2, 2008 | 11:31 AM
V10_Cougar's Avatar
V10_Cougar
I get minimal rubbing when making a sharp left or right turn. This happens when entering small compact driveways and or a very, very sharp turn. In this case I should have gone with a 6.5 in lift. But all in all, it's nice when towing a TT and it's really nice on off-road. These tires seem to like mud/rocks, my last pair of shoes (BFG A/T) were excellent set of tires but off-roading was minimal.
When you get a chance? Post some pics of the lift with your new tires.
Good Luck!!!
BTW- WELCOME TO FTE!!!!!!!!!!!
pumpdriver20
Feb 11, 2013 05:41 PM
Redneckfordf2502002
Sep 28, 2012 02:31 PM
302F250
Mar 25, 2008 10:00 AM
jdraughn
1983 - 2012 Ranger & B-Series
Dec 26, 2007 01:08 AM
