I have a 2000 f150 extended cab that is two weeks old. I have some paint overspray covering the truck and i want to know if anyone has any ideas on how to get it off. I do not know what kind of paint it is and it would not come off with normal washing.
yo,
this is a common problem. If your truck came that way, take it back and have the dealer remove the overspray. Most detail shops can remove it by using the clay bars and then using 3M Perfect-It Hand Glaze .. sometimes, the clay bars will pick up grit and actually cause some fine scratches in the clearcoat.
Good luck,
al
