EGR valve. Replace whole Unit or Sensor??
Old Nov 30, 2008 | 06:40 PM
BRay09's Avatar
BRay09
Exclamation EGR valve. Replace whole Unit or Sensor??
Vehicle Specs:
1989 F250 w/ 351w
c6 tranny
4.10 gears
K&N FIPK
31,000 actual miles
Getting 6-8 mpg in highway/city driving.Was told EGR valve could be the problem.
Should I replace the whole EGR assembly in my truck or is there a way to free up the unit somehow. I'm getting a code 33 saying "EGR valve opening not detected". Took it to a shop and they told me they could look at it. For $75 an hour... Trying to save some green and want to do it myself.
Any thoughts?
Old Nov 30, 2008 | 06:58 PM
danr1's Avatar
danr1
Chances are better you have a vacuum leak, a bad EVR or a bad EVP. The EGR valve itself is probably working.
EGR valves are built to last, but a quick easy test, connect a hand vac directly to the the EGR valve, pull say 12-15hg of vacuum on it, the idle should drop couple hundred rpm's with motor stumbling. If it does, and holds a solid vacuum, value doesn't drop, the EGR valve is fine.
Testing procedures for the EVR and EVP can be found with a quick search here, if not post back and I'll post em for ya.
Old Dec 1, 2008 | 08:11 AM
BRay09's Avatar
BRay09
Im not exactly sure on how to do this. And i know i don't have a hand vacuum laying around the house. Can you get one of these from an autoparts store?
