check engine
Old Nov 30, 2008 | 03:41 PM
WALJON's Avatar
WALJON
check engine
Hi my wife drives a 98 exp ,for some reason the check engine light comes on when she fills up with gas It only happens when she fills up all the way she said if she only puts in say half a tank it doesn,t come on? I know this has to be some kinda silly emissions thing but what can I do to get this to stop.
Thank you.
Old Nov 30, 2008 | 04:03 PM
pdqford's Avatar
pdqford
First thing I'd do is have someone (AutoZone?) pull the codes to see specifically what the PCM has detected. (Be sure and write the codes down as they have a way of becoming muddled over time
If you need more help after you have the coes pulled, post them to this thread and someone will respond with advice.
Old Nov 30, 2008 | 04:39 PM
WALJON's Avatar
WALJON
Thanks that was my plan just figured maybe someone had run into this problem and had an easy fix or something I could check myself like a gas cap not sealing or something similar.
panteramatt
Jun 9, 2016 10:42 PM
imcqueen
21
Dec 31, 2015 10:55 AM
ajg617
Jun 11, 2015 08:08 PM
AXracer
21
Mar 6, 2014 01:30 PM
abclay
Nov 17, 2012 04:15 PM
